Login
YoutubeInstagramRSSGithubPatreonPrivacy
Fixt â€ĸ Š 2025
Updated: Oct 6, 2023—4 min read
ESPresense v3 - Room level presence detection with ESP32 and Home Assistant
PrerequisitesInstall Mosquitto Broker Add-onESPresense InstallationHow to track your Android Phone How to track your MiBand How to track your iPhoneHow to Create a SensorHow to use it with a Device TrackerAutomation to translate ESPresense Sensor to Device TrackerManage People in HAMake your music Follow you around the house
Easiest way to Control your Smart Home with AI: Ollama + Home AssistantEasiest way to Control your Smart Home with AI: Ollama + Home Assistant
Make you music follow you with ESPresense Room Presence DetectionMake you music follow you with ESPresense Room Presence Detection
Automation
ESP32 Dev Kit
  • ESP32 Development Board
    • Amazon: (3 pack)
    • Aliexpress: (30PIN microUSB)
    • Aliexpress: (38PIN microUSB)
  • ESP32 Case with Home Assistant Logo to 3D-print:
    ESP32 Dev Kit
    • 30PIN microUSB
      ESP32 Dev Kit
    • 38PIN microUSB
Click here to be redirected to the ESPresense Installation page.
Install the Home Assistant Companion App
Install to be able to track your Android Phone with ESPresense
Notify & Fitness for Mi Band
Install to activate discoverability for your Mi Band if not present on the Zepp Life App
iOS Enroll flow
just add /ui to you ESPresense IP address
Follow the instructions on the screen to enroll your iOS device for Reliable BLE tracking
config/configuration.yaml
sensor:
  - platform: mqtt_room
    device_id: "iBeacon:xxxxxxxx-xxxx"
    state_topic: 'espresense/devices/iBeacon:xxxxxxxx-xxxx'
    timeout: 10
    away_timeout: 60
config/known_devices.yaml
oneplus7:
  hide_if_away: false
  mac:
  icon:
  picture:
  track: true
config/automations.yaml
alias: Update OnePlus 7 Device Tracker
description: ""
trigger:
  - platform: state
    entity_id:
      - sensor.oneplus7_ble
condition:
  - condition: template
    value_template: "{{ trigger.from_state.state != trigger.to_state.state }}"
action:
  - service: device_tracker.see
    data:
      dev_id: oneplus7
      location_name: |
        {% if trigger.to_state.state in ['livingroom', 'entrance', 'bedroom', 'bathroom'] %}
          home
        ## Erase the next two lines if you don't want to use the not_home state
        {% elif trigger.to_state.state == 'not_home' %}
          not_home
        {% else %}
          unknown
        {% endif %}
mode: single
Manage People in HA
Open your Home Assistant instance and show your people.
Full tutorial here
Automation
Automation
